Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 06-04-2009, 01:14 PM
zombe1961 zombe1961 is offline
2002 Bravada AWD Turning Issues
WHEN I TURN THE WHEEL HARD TO THE LEFT OR RIGHT.Tight turns it seems to be binding up the front end. You can feel it in the steering wheel and floor.
Old 06-04-2009, 03:26 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Exclamation Re: 2002 Bravada AWD Turning Issues
I'd suggest taking it to a certified SAE mechanic ! The steering system on your car is a vital part for your safety . It's not something you would want to have questions about when you're driving down the road !
Old 06-05-2009, 08:51 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Guess the drivers side hub & CV joint going out now huh, since you recently replaced the passenger side?
I guess it can get so wobbly it'll cause the brakes to drag.
Need to take care of it pretty quick, ya don't want it to get an uncontrollable wobble(Death Wobble) which could cause you to loose control at highway speeds.
Old 06-05-2009, 07:20 PM
I replace the hub the same time I did the passenger side.
CV Maybe. I will check. I thought it was the front diff.
Old 06-24-2009, 09:10 AM
OK, changed CV on drivers side I am still feeling the turn bind at real low speed and more than 90 degree turn. It feels like the car will stall out. I let off return the wheel back to straight and it stops. It is intermitent. HELP!!
Old 06-24-2009, 10:57 PM
AF - Advisor
Sounds like the Smartrak is binding up doesn't it? You might try pulling the ATC(Smartrak) fuse and see if that helps.
Old 07-22-2009, 08:07 AM
It helped Still feels a little different. Gas milage is much better.. Can I leave it like this? Will it cause any problems.
Old 07-23-2009, 06:32 AM
AF - Advisor
If pulling the fuse really helps then the transfer case should benefit from a fluid change to the blue AutoTrac II lube to help unstick the internal parts.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
