Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-04-2009, 11:34 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
car runs hot
yesterday on my way to home from work my air conditioning started to blow hot, so i checked the gauges and my coolent temp was 3/4 of the way up the gauge (normally just under 1/2) the water pump was changed with the timing belt (@ 60,000; 5,000 miles ago) and so was the coolent. what else could cause this problem? if it is the Thermostat, i would like to replace it with a cooler one, but do not have time to waste with ordering and shipping. the car needs to be back on the road by 4pm tomorrow. let me know your guys thoughts, and opinions on the new thermostat (if that is the probable problem) any information is greatly appreciated.
Old 06-04-2009, 12:08 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: car runs hot
The two things I go for right away when people start having over heating problems are the thermostat and a new radiator cap. Combine that with possible air in the system and you can solve 95% of all overheating problems.
Did you check the actual coolant temp with the DSMLink? They, the gauge and the ECU, get fed by different sensors so you never know about the condition of one sensor without looking at the other.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 06-04-2009, 12:46 PM
Black99GST's Avatar
Re: car runs hot
what temp should i go with for the new thermo? 170 deg the best option?
Old 06-04-2009, 03:04 PM
Black99GST's Avatar
Re: car runs hot
going to pick up a new 170 deg thermostat, and a new radiator cap in about 30mins. hope this solves my issues. any tip on changing the thermostat other then whats in the manual? never done it before, so any tips or tricks are great. seems pretty straight forward though. should be fine, and go smoothly. thanks.
Old 06-04-2009, 05:12 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: car runs hot
Take old one out, put new one in. I don't know if yours is split like the 420a housing. Would get a new gasket too if it is. Then I always put gasket seal on the gasket when closing back up.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-04-2009, 05:31 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: car runs hot
As far as putting in the new thermostat just pay attention to the way the old one was put in. Don't install it upside down. The side with the spring should go in first. Hopefully that will solve the issue.
Last summer I had issues with my car overheating, coolant was full with a new radiator cap, and thermostat.
I ended up installing a slim line fan and wired the radiator fan and ac fan, so they would both turn on at the same time. I installed new shrouding around the FMIC and the radiator so most of the air would be directed through the radiator. That helped alot but still didn't lower the coolant temps enough. I bought a new mishimoto radiator which holds a little bit more coolant and added a bottle of redline water wetter. After all that I don't run hot anymore and the coolant temps stay just below the middle of the gauge like it did before I installed the FMIC.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 06-05-2009, 10:26 AM
Re: car runs hot
Be careful with that 170 degree thermostat. In order for the ECU to enter learn mode, all of the following conditions must be true.
Coolant temp >= 180F
Intake air temp < 133F
Baro >= 22.9 inHg
Baro <= 31.6 inHg
So if your coolant temp never reaches 180 or higher, the ECU will never enter learn mode and your FT's won't get updated. Basically the ECU will think the car is always warming up.
1997 Spyder GS-T
5-Speed
Old 06-05-2009, 11:53 AM
Black99GST's Avatar
Re: car runs hot
good call on that, so i should stick with the 180 deg. thermostat? i found the issure before taking anything appart, actually, all i did was open the hood for the first time in a while, and found the problem. my boost controller feed (charge side) line had blown off the charge pipe nipple, and wrapped itself around the radiator fan, causing it to not rotate... i can take the thermostat back and swap it out for the 180 deg one. i know once coolant temps reach 200 deg it pulls timing, and being in the Texas summer, 100 deg weather outside, the heat is hard to beat... this is the original reason for the thermostat switch. :-/
Old 06-05-2009, 01:17 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: car runs hot
Timing is pulled at 210, IIRC.
Kris
2012 Genesis Coupe 2.0t
