Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-03-2009, 05:48 PM
dvk44039 dvk44039 is offline
Lincoln ls 2003
Having a problem tracking this down. Have a P0108 on 2003 ls 302 the code comes back as bmp/map senser out of range. Local ford dealer says no such senser on that car. so does parts stores.
thanks don
Old 06-03-2009, 07:24 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Lincoln ls 2003
P0108 - BARO/MAP Sensor High Voltage Detected Sensor operating voltage is greater than 5.0 volts
You probably have a Mass Air Flow Sensor. That is where the Baro reading will come from.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-04-2009, 04:08 AM
Re: Lincoln ls 2003
Thats kind of what ifigured as the woman said she had her brother get one and replace the maf sensor. But she said he got it from a ford dealer. Will check pins in plug and wires. any other ideas?
thanks don
Old 06-04-2009, 07:55 AM
way2old's Avatar
TOKEN HILLBILLY
Re: Lincoln ls 2003
You have 3 options on that code. Here is information needed to see which test to run.
P0108
Vehicles with ESM EGR
Vehicles with MAP or TMAP sensor
Vehicles with BARO sensor
