Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 06-03-2009, 01:59 PM
titantn24 titantn24 is offline
'00 Civic EX using oil
OK, my '00 Civic EX has around 156K miles and runs great. I checked the oil the other day and found that it was a little over a quart low. It had been about a month since it was last checked and topped off. This was the most it had ever been low. I exclusively use Mobil 1 5W-30 synthetic oil and Mobil 1 oil filter. Have ever since I bought the car w/ 59K miles on it. I perform all maintenance as required. I drive at least 400 miles a week, 95% highway/interstate. The car doesn't smoke at all, so I don't think it's burning the oil. There are no signs of leakage in the driveway either, so I'm not sure where it's going. I know this seems like a silly question, but what could be happening here? All suggestions are appreciated. Thanks in advance.
2000 Honda Civic EX--
AEM CAI, Unorthodox Racing lightweight crank pulley, 17" Motegi Racing MR7's, rest is all stock(work in progress)
Old 06-10-2009, 04:32 PM
rustysurfsa rustysurfsa is offline
Re: '00 Civic EX using oil
You are burning oil slowly.
Old 06-12-2009, 10:58 AM
That makes the most sense. Now, some new questions. I assume replacing the piston rings would fix this problem. Is it worth it to do this or should I just keep topping the oil off? I also assume that it will progressively get worse? I've heard of others going to a heavier weight oil to help with this. Is this a good idea? I know 5W-30 is the recommended weight for this engine. Is using a full synthetic worthwhile now that I know I am slowly burning it? Or would going to a conventional oil only make it worse? Sorry for all the questions. Just trying to find the best course of action. Thanks again.
Old 06-15-2009, 08:57 PM
bluevp00's Avatar
bluevp00 bluevp00 is offline
If you really want to fix the oil burning problem then it is much more cost effective to replace the engine as a whole, but that's still asking a lot. It would rather be wise to refill the engine with a heavier oil, Mobil 1 10W-40 would be a good choice, and see what kind of improvements you can see. Remember, when the engine burns oil internally, it is mileage, not time, that is the factor.
Old 11-15-2009, 07:55 PM
3M1mugen 3M1mugen is offline
def sounds like rings..if heavier oil dont work,it might be the beginning of worn rings
Old 11-15-2009, 07:56 PM
try a compression test,then check each plug for deposits
Old 11-24-2009, 09:08 AM
UPDATE:
Ok, my father and I were working on the car this weekend (A/C compressor) and out of curiousity I took a closer look underneath. Upon examination, I noticed oil on the transmission side of the oil pan. I can't tell exactly where it's coming from. I do know it's not coming from the oil filter. I was thinking maybe the oil pan gasket, but my dad suggested it might possibly be the rear main seal? He said either way that the entire engine would have to come out to repair and that a rear main seal replacement is a pain. The "leaking" oil isn't enough to create a spot on my driveway where I park, so this must be a slow leak. Any thoughts on the best course of action? I just hit 166K this morning and would like to keep this thing going for at least a couple more years. I don't know anything about rear main seals, so if someone has experience w/ this, please share any info you have. Thanks.
Old 01-16-2010, 12:06 AM
TommySI1997 TommySI1997 is offline
Thumbs up Re: '00 Civic EX using oil
yeh bro sounds like a ring problem.. unless you race your civic alot..i had alot of buddys with the same problem.. but then found out it was because of racing alot, have you tryed Royal Purple oil 5W 30 ive found out they work better for civics. well v-tec engines.
tommy
Old 01-25-2010, 04:32 PM
pigeonkiller23's Avatar
pigeonkiller23 pigeonkiller23 is offline
Originally Posted by titantn24 View Post
UPDATE:
i would find it alot easier to take out the engine and the tranny as whole and then separating them when theyre out of the car. it would be alot easier to change the seal when you have more room. in my experiance royal purple makes a difference in power but not for leaking problems. my civic burns oil but its because of the high compression pistons i have in there. i run 10-40 mobil 1 in mine and its good. it burns oil but very very little. i would suggest going up to 10-40 to see if there is a change in burning oil. also if you could completely clean were its leaking after the oil change to see if thicker oil makes the difference in the leaking.
