Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 06-03-2009, 09:42 AM
jack1018 jack1018 is offline
GM Fuel Filter disconnect fitting
Anyone knows how to disconnect the black fuel line fitting? It is on a 96 Sunfire 2.2.
Old 06-03-2009, 10:20 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: GM Fuel Filter disconnect fitting
take a blow gun and blow all the sand and dirt that has accumolated in the fitting. Push the black part to the right (as it is shown in the picture you posted). You will know it is far enough when it bottoms out on the metal part of the line (you can see the metal line in the grooves of the black plastic piece. Then pull off the line from the filter.
Now that it said they never go that smooth! they usually either break or the line is rusted to the point where it can no longer be removed from the fitting easily. If the black piece breaks it can be removed completely and a quick disconnect tool can be used to get the line off. More often than not I usually break them off, pick out all the pieces, blow out all the dirt, spray liberally with penetrating lube, and use a quick disconnect tool. Then twist, pull, push for the next 20 minutes until the 2 separate.
I hope it goes smoother for you!
Old 06-03-2009, 10:34 AM
wrenchboss26's Avatar
wrenchboss26 wrenchboss26 is offline
The only thing I do different is use spray silicone lubricant, it seems to work better for me than penetrating oil does.
Old 06-03-2009, 12:17 PM
Thanks for the input. I have two questions. 1) What is the function of the black plastic piece? 2) If it gets broken, do I need to replace it? Thanks
Old 06-03-2009, 01:07 PM
Airjer_'s Avatar
The black piece is the release mechanism that allows you to "unlock" the retainer and remove the fuel line without a tool. They would have done everyone a favor if they had left it off! Also if the metal clip that the plastic piece unlocks becomes damaged they are available aftermarket.
*My 1,000th Post!* yeah!!!!
Old 06-03-2009, 01:12 PM
Thanks
