Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-03-2009, 05:10 AM
Thatboyuhate Thatboyuhate is offline
You guys seem to know ur stuff, try this one out
scenario: im driving along and all of a sudden something doesnt feel right, i press down on the accelerator and i get nothing, as if im not even pressing the gas...i pull over, wait, starts up fine but again, as if im not even pressing the gas.
I manage to putt putt it home and later try again, seems normal now, still a little iffy but it might b because i expect something to be wrong.
What the hell is going on???
Old 06-03-2009, 09:48 AM
wrenchboss26's Avatar
wrenchboss26 wrenchboss26 is offline
Re: You guys seem to know ur stuff, try this one out
Year, engine, tranny, was the check engine light on, does it have a check engine light, need more information.
Old 06-03-2009, 10:13 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
How about a year and engine size?
Old 06-03-2009, 10:32 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
yes, more info definitely needed. The first thing that comes to mind is debris in the gas tank. I had a joker stuff a plastic bag into a gas tank and it did exactly as you describe. The debris gets sucked onto the pick-up pipe and reduces fuel flow. If the engine is switched off long enough, the debris floats away, allowing normal operation, for a while.
Alternatly, it might be fuel pump, regulator or filter. A fuel pressure check might help.
Old 06-03-2009, 11:26 AM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
Is it surging or struggling? could be a bad seal in the intake piping - too much air coming in after the sensor really pisses off the computer.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 06-20-2009, 12:49 PM
K5Calamity's Avatar
K5Calamity K5Calamity is offline
My 2 cents, ignition control module, but it could be 1 of 50 things.
Old 06-24-2009, 05:46 PM
OldSVTGuy OldSVTGuy is offline
Might be a clogged fuel filter, too. When was the last time it was replaced?
