Old 06-02-2009, 06:42 PM
JeenyusVR4 JeenyusVR4 is offline
Help with window problem!!
Ok so my passenger window won't go up or down using either the drivers side or the passenger side switch. So i unplugged the connecter to the motor and just powered it with my battery and it works perfectly. I also just put battery power to the connector at the switch and it made the window go up and down. So then i tested power to the switch and everything is getting power, so i thought it was just the door switch so i got a new one and it still doesnt work. So today i tested out some more. I checked for resistance from the connector inbetweeen the door to the connector at the switch and it had .1 ohms so that checked out fine. Then i ohmed out from the switch connector to the connector at the motor and it also came out to .1 ohms. So ive come to the conclusion that there are no problems with the wiring and the motor works fine. Im am completely stumped on this one, if anyone has any ideas i would greatly appreciate it.
Old 06-02-2009, 07:15 PM
quackmandude quackmandude is offline
Re: Help with window problem!!
check for loose wireing. is there a relay the switch goes to? im not sure thats enough ohms
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6)
Old 06-02-2009, 08:39 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Check the window lock.
Old 06-02-2009, 08:44 PM
Girly VR-4 Girly VR-4 is offline
you hit the window lock button. un-lock it.
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 06-02-2009, 09:03 PM
Stealthee's Avatar
Too slow Em.
Old 06-02-2009, 09:31 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
I will bet you that is the problem. It is ok, I have WAY overlooked problems before too. I remember a couple years back I had to take my mom's car pick some stuff up and it would not start. I tried jumping the battery, and it still would not even turnover. I then checked how much power was getting from the battery to the starter and everything appeared to be fine. Turns out the damn car was in drive with the park brake on so it wouln't start unless it was in neutral or park. However, I did not take the time to look at that.
Old 06-02-2009, 09:52 PM
Stealthee's Avatar
Maybe it was you, maybe it was someone else, but I remember someone from here IMing me one evening about an issue.
They said the ignition wouldn't turn at all. Said they tried everything and was about to drill the ignition out.
I told them to wiggle the steering wheel while they turned the key and see what happens.
They came back minutes later and said something along the lines of "Son of a bitch. I never thought of the steering wheel being locked would prevent the key from turning"
Old 06-02-2009, 10:24 PM
yea yea, I should probably read all of the replies before posting
www.3swarehouse.com
Old 06-03-2009, 11:40 AM
HAHAHAHAHA WOW thats prolly one of the most embarrasing things thats ever happened to me lol. But ya i unlocked the window lock and still didnt work then i put in the new window switch i bought now all is good. Wow i still cant believe i missed the most simple thing. Well i guess it happens thanks alot guys!!
Old 06-03-2009, 02:40 PM
VR43000GT's Avatar
I don't think that was me as the steering wheel moved fine and it is something I already knew about (I guess I also knew that I couldn't have it in drive while trying to start the damn thing but just over looked it lol). However, it is one thing I have learned is to start with the very very basic things first when trying to diagnose a problem.
