Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-02-2009, 01:51 PM
nick8519 nick8519 is offline
Cool Headlights on most of time
I have a 2006 Impala LT with automatic headlights. They are on all the time even during the day. The car does not have daytime running lights i believe. From looking at other Impalas around time I notice most do not have headlights on.
Any thoughts on this?
~Nick
Old 06-03-2009, 07:18 AM
sroney sroney is offline
Re: Headlights on most of time
On my 2000 impala, the DRL's are the low beams. So it looks like the low beam headlights are on, but they are in fact the DRL's.
Not sure about your newer model.
Old 06-03-2009, 08:23 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Are ALL the lights on, including the tail lights and the side marker lights?
If yes, there may be something wrong with the lightswitch, or it may have an aftermarket daytime running light setup.
If it is just the low-beam lights and nothing else, then you have factory daytime running lights (DRL's)
FWIW factory DRL systems use a reduced-wattage system and are dimmer than the regular headlights. The low-beams, on DRL setting use just 25 watts instead of the full 55-60 watts.
Do your lights look dim, or have full brightness?
Old 06-03-2009, 02:38 PM
thanks for the input guys. i have concluded they are DRL's. i had it in the dealer today for an oil change so i picked the service writers head about it. for some reason i just had it in my head that they didnt do that before. anyways...
thanks!!
~Nick
Old 06-03-2009, 03:04 PM
HeMi101's Avatar
HeMi101 HeMi101 is offline
Send a message via AIM to HeMi101 Send a message via MSN to HeMi101 Send a message via Yahoo to HeMi101 Send a message via Skype™ to HeMi101
Just another FWIW: 2000 - 2004 Impala DRL are The highbeams running @ 50% wattage, and 05's are the low beams, Not sure if they drop wattage or not. 2006+ is the low beams.
Old 06-03-2009, 05:54 PM
jtav2002 jtav2002 is offline
Send a message via AIM to jtav2002
Yea as you've concluded you have DRL's. You can turn them off by flicking your headlight switch over to the left. Or eliminate them altogether by removing the DRL fuse in the engine compartment fuse box, this has no effect on the automatic headlights.
Josh
2009 Toyota Tacoma 4x4 access cab TRD Sport
2007 Impala SS - gone
