Old 06-02-2009, 11:30 AM
persuazion persuazion is offline
Security light blinking....car wont start.
Ok this issue has been getting on my nerves lately. At first it would only happen every now and then but now its happening more and more. I go to start my 99 lesabre and nothing....just the security light blinking. Sometimes if I pull the steering wheel up and down it goes to on and the car will start.But that hasnt been working recently.Now I read somewhere that you put the key in and leave it for 10 mins well I did that and the light went off but now my car sounds like the battery died....clicking and interior lights flickeriing when I try and start. Did I kill my battery now?? What should I do? ThANKS
Old 06-02-2009, 05:10 PM
Re: Security light blinking....car wont start.
ok well I tried everything I could think of......battery was dead so went and got a new one. Saw some wires hanging down from behind the dash by gas pedals...moved them around. The light stopped flashing....car started. What does this mean??
Old 06-03-2009, 05:03 AM
thisnametooktolong thisnametooktolong is offline
this is the only post you need to read! the plug is dirty, or those solid wires they use on the VATS are broken inside the harnes
I would bypass the VATS for two reasons. It is hard to find the broken wire because it is intermetent, two, then you can use a very inexpensive non vats key. for photos and directions
vats.likeabigdog.com/
Old 06-03-2009, 09:55 AM
Andreas E.'s Avatar
Andreas E. Andreas E. is offline
What thisnametooktolong said. My 92 Lesabre started doing the same thing last year. I went to Radio Shack, got the necessary parts for a few bucks, put it together and installed it. All in all, it was an easy fix. In my Lesabre there is some of the heating/cooling system mechanism behind the glove box. Be careful to position the "add-on" resistors in such a manner that they won't interfere with the mechanism or it'll rip the fix apart.
Old 06-04-2009, 01:43 AM
happydog500 happydog500 is offline
I did this on my 97 a couple years a go and it was easy and fixed it.
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
