Go Back   Automotive Forums Car Chat > Plymouth > Acclaim
Old 06-01-2009, 05:24 PM
mitchc mitchc is offline
Oil Light flickers on and off
93 model. 178K miles. The oil pressure light came on a couple of weeks ago. The oil pressure switch was leaking quite a bit so I replaced it and that appeared to fix the problem. Now the oil light comes on with forward motion for a few seconds and then goes off. If I accelerate it comes on for a few seconds (less than 6) and then goes off. it does not come on when in neutral or park even if I rev the engine. Does not come on in reverse.
I don't know how to check the pressure since I only have an idiot light. Engine runs fine, no bad noises.
Could the switch be bad or could it be the oil pickup?
Any help appreciated.
Mitch
Old 06-19-2009, 08:21 PM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
Re: Oil Light flickers on and off
I know this is a dumb question but did you check the oil level after you changed the oil pressure switch?
1999 Purple Plymouth Neon SOHC Automatic
Bought Feb 2009 For $700
125,000 miles
Maybe the world record for car with most hidden zip ties
