Old 05-31-2009, 04:37 PM
rundle rundle is offline
Exclamation AC Issues - Suggestions needed ASAP
The air won't get cold in my daughter's 2000 Grand Prix. Here is what has been done so far: new relay switch, checked fuse, new low pressure switch, compressor has checked out good, has freon.
Also, washed vehicle the other evening and washed motor - after this ac worked for a short period of time. We have taken car to two mechanics and they have checked/fixed the above mentioned. Both have given up - can't find what problem is. Now what???
Old 05-31-2009, 09:17 PM
brcidd's Avatar
brcidd brcidd is offline
Re: AC Issues - Suggestions needed ASAP
Number one failure mode of automotive a/c systems is lack of cooling due to loss of refrigerant due to a leak--- you say it has "freon" - how much?? You cannot tell by the pressures you know-- 4 ounces will have the same static pressure as 4 lbs in your car.. so I am willing to bet you have about 8 ounces in a 1.88 lb system-- so look for your leak-- compressor shaft seal and compressor belly o-rings are most common leak location.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-31-2009, 09:45 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
You say you washed your car and the AC started to work for a short period of time?
Have a look at your radiator and AC condenser. Make sure they are not covered in dirt. If the condenser is covered, no air will be allowed past it, and the heat exchange cannot happen. Thus causing warm air.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-31-2009, 10:01 PM
Both mechanics assure us that there is not a leak (thus their frustration). I don't know how they checked it but they both say there is plenty of freon and it isn't losing any.
The radiator and condenser have been checked - say it is okay - not dirt covered.
(Took to mechanics after washed motor and air quit again.)
Old 06-01-2009, 01:13 AM
tblake's Avatar
In God We Trust
analog or digital hvac controll?
Old 06-01-2009, 06:05 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
As Tim asked, digital climate control or manual HVAC? Also, when you command AC on, does the compressor clutch engage? Have they measured both high and low side pressures and if so are the readings within specs for the then current ambient temp and humidity?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-01-2009, 05:12 PM
manual HVAC
Compressor clutch does not engage
both checked high and low side pressure - readings were within normal limits for current temp/hum
Old 06-01-2009, 09:19 PM
tblake's Avatar
In God We Trust
How can the readings be within the normal limits if the compressor doesnt engage?
3100 or 3800?
Old 06-01-2009, 09:44 PM
I know nothing about cars - just giving the information that I got from the two mechanics I've taken car to.
How do I tell if it is a 3100 or 3800?
I guess I am going to have to take it in to a dealer - the two mechanics we took it too came highly recommended from several individuals.
Old 06-02-2009, 07:13 PM
tblake's Avatar
In God We Trust
Uh Oh!
I'm referring to the motor size. If its a 3.1 or 3.8, becuase I think the 3.1 has a different compressor that actually cycles on and off whereas the 3.8 I believe has the GM V5 type compressor and it constantly is running when the motor is.
Old 06-02-2009, 08:39 PM
It is a 3100 (if the big numbers on top of the motor are correct!)
We appreciate the help.
Old 06-02-2009, 08:40 PM
brcidd's Avatar
They all have V-5 compressors 1996 and beyond-- HD-6 compressors came off 3800's in 1996-- never to come back..
'99 GMC Yukon
Old 06-02-2009, 10:20 PM
tblake's Avatar
In God We Trust
Thanks for clarifying!
Old 06-03-2009, 07:06 AM
richtazz's Avatar
If the compressor isn't kicking on the pressures cannot be within spec, so I would strongly suggest you take your car somewhere else. Strongly recommended or not, these mechanics don't know what they're doing as far as A/C work goes anyway. Maybe they have other talents, but obviously A/C work isn't one of them.
Old 06-03-2009, 09:06 AM
tblake's Avatar
In God We Trust
Thats a nice way of putting it Rich!
