Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 05-31-2009, 04:05 PM
woodchuckman woodchuckman is offline
98 A/C pressure cycling switch
Where the heck do I find the pressure cycling switch on my 98 Achieva?
Thanks, Mick
Old 05-31-2009, 09:20 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 98 A/C pressure cycling switch
What the heck- there is none....not designed that way- you have a variable compressor- does never cycle by design-- is quieter that way--
I assume you want the switch so you can jumper it to add refrigerant--
well no need to - just hook up your can, when system pressure hits 47 psi the compressor will kick on...but you need to find your leak--compressor belly and shaft seal are number one leak locations on the V-5 compressor you have..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-01-2009, 07:00 AM
Actually, the compressor won't run at all. I was going thru the wiring diagram in the haynes manual and eliminated any other switch or relay (they all work), and that's the conclusion I came to. Have not checked the refridgerant level yet, will do that soon.'
Thanks, Mick
