| Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here. |
power numbers?
-B-303 CAM, 24lbs injectors, 1.6 rockers, Trickflow Aluminum Heads, Trickflow upper/lower intake manifolds,75 mm mass air, 75mm throttle body,75mm egr spacer, BBK Cold air intake, its all in a 90 lx whtat do you think the hp and torque numbers will b around?
Re: power numbers?
hard to say, alot goes into tuning... If its tuned right i would ballpark it at a little under 400hp, and a little over 350 lb-ft torque.
"When Lightning Strikes the Heartbeat Stops!" '91 Mustang LX 347 StRoKeD & BlOwN '04 Ford F-250 6L PS FX4 '95 Ford F-150 Ford Racing Pride General Motors who? ![]() 2004-2008 Ford Master Certified Technician |
Re: power numbers?
Best guess is 400-425 hp. torque probably 380-400. Keep in mind this is flywheel hp. In an LX you should be able to run mid to high 12's with this combo.
Meaning....On the street you'll put the boot to most of them out there.
