Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-30-2009, 11:27 PM
JonathanH2286 JonathanH2286 is offline
Engine Problems!!
I have a 2g 97 eclipse 420a motor. I'm getting really bad gas millage and the car will die for a split second when driving. It does it at all different RPM's and speeds. I have replaced the O2's and the spark plugs and the fuel filter and have checked for any arching and any vacuum leaks but haven't found any thing. I did replace the header and the down pipe but that should not be the problem. Any Ideas or more information you need ask and I will give the best info I can thanks.
Old 05-31-2009, 12:06 PM
Pushin_20s Pushin_20s is offline
Re: Engine Problems!!
im having the same problems with my talon and have replaced fuel filter and full tune up. im getting a check engine light with a obd code reading of P1296, i still dont know what this problem could be
Old 05-31-2009, 02:52 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Pushin_20s
I used this website: http://codes.rennacs.com/PCodeSelect...commonRepairs=
P1296 = This Relates to MAP sensor - no voltage supply
Check the wiring that connects to your MAP sensor where your intake is. It could be loose or unplugged. The wires could even be damaged.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 05-31-2009, 11:58 PM
Thanks I actually went a head and took off the throttle body and cleaned it then disconnected the battery and the car runs great!
