Old 05-30-2009, 10:09 PM
cicca_294 cicca_294 is offline
Paint troubles
hey guys, im using automotive touch up paint, metallic purple...
the first coat came up really nice, glossy and alll..
then i went for the second coat, and its actually started drying as a flat purple, with a rough film almost..
this is the first problem ive had with the brand, and was just wondering if yous know wats goin on...
also, i do heat the paint up before use.
Old 05-30-2009, 11:34 PM
CFarias's Avatar
CFarias CFarias is offline
Re: Paint troubles
First, check to see if you paint is a base coat which is to be used along with a gloss clear, or clearcoat. Look for a "CC" next to the name of the paint.
If you see the "CC" then the paint you are using is suppose to go on flat. It dries quickly, but requires a clear gloss to be applied onto it to bring out a true shine.
Sometimes, under certain conditions a basecoat paint can go on glossy, particularly if it goes on heavy.
Typically these paints don't need to be pre-heated.
Tell us more about your problem. Are airbrushing or spray-canning? What brand are you using? etc....
Old 05-31-2009, 02:34 AM
Re: Paint troubles
ok, so it does have much on the whole cc thingo, but i figure its touch up paint so it should go on glossy...
and its a spray can, 'power plus' is the brand, though im not sure if that makes a difference, it just from the local car shop......
i have photos..
Old 05-31-2009, 02:44 AM
Lownslow's Avatar
Lownslow Lownslow is offline
Re: Paint troubles
youre in the good thats a base metallic. clear will fix that right up stick to the same brand.
Old 05-31-2009, 08:26 PM
CFarias's Avatar
Re: Paint troubles
Indeed as Lownslow said. Spray on some same-brand gloss clear and you should have a magnificent shine.
Incidently, it will also fix any discoloration you might be seeing in the basecoat paint. That's a natural part of the finish that will go away once the gloss is applied.
Old 05-31-2009, 09:56 PM
Didymus Didymus is offline
Re: Paint troubles
The single part PPG and Dupont color coat sold by automotive paint supply houses in small quantities is a one-part urethane that dries to a smooth semi-gloss finish. It's used by paint shops for small jobs. It doesn't have the durability of two-part urethanes, but it's fine for modeling purposes. It has to be mixed 1:1 with a medium temp reducer like UR40.
If that's what you're using, it can be clear coated with either two-part clear urethane or with synthetic lacquer clear coats like U-POL or Tamiya TS-13.
Two-part urethane dries to an orange-peel free, ultra glossy finish. Hiro sells Zero two-part urethane in small quantities; other than that, it's almost impossible to obtain in small amounts.
Ddms
