Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-30-2009, 07:27 PM
earlpitts earlpitts is offline
Gauges dropped engine died
97 Eclipse 2.0 NON turbo. The gauges dropped and the engine quit. the car will turn over now but will not start. Any ideas anyone as to were to start looking?
Earl Pitts..... Proud To Be An Uhmerikun!
Old 05-30-2009, 08:00 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Gauges dropped engine died
Is your Check Engine Light on at all?
When you listen in on the back seat, do you hear the fuel pump kicking in?
Do you have spark?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-30-2009, 08:07 PM
Check Engine light Is on now..yes..Im not sure about the fuel pump running. Is there a fuse which would do all this? The car was purchased with a bad ECU and the ECU in it now came from a junk yard
Old 05-30-2009, 08:09 PM
david-b's Avatar
Dave is THAT guy
I would get or rent some sort of CEL tester. If the car doesn't run, I believe you can rent them at Autozone for pretty cheap. That would be your best bet to see what's causing the CEL to trip before checking anything else. I bet that leads straight to your problem.
75 Monte Carlo
Old 05-30-2009, 08:16 PM
I do have a CEL tester but im not where the car is now. I will run the test tomorrow...what has me confused are the gauges dropping to zero right before the car died
