OO Grand Am GT Key FOB
When I do steps 4 through 6, on my 2000 GrandAm GT, I never get any chime. Where do I start trouble shooting this? Everything else seems to be working. I'd sure be nice to have a working fob! Thanks in advance for any advice or tips.
![]() To program the transmitters, perform the following procedure while seated in the vehicle driver's seat: 1. Close all the vehicle doors. 2. Remove the ignition key from the ignition lock cylinder. 3. Press and hold unlock on the door lock switch. Important To successfully enter the keyless entry programming/diagnostic mode, steps 4 through 6 must be completed within 25 seconds of pressing the door unlock switch. 4. While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder. 5. Insert the ignition key a third time leaving the key in the ignition lock cylinder. The ignition must remain in the LOCK position for the rest of the procedure. 6. Release the door lock switch. The chime will sound three chimes to signal that transmitter programming/diagnostic mode is active. 7. Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for approximately 4 seconds. The chime will sound two times to signal that the transmitter has been programmed successfully. 8. Repeat step 7 for the rest of the transmitters (for a total of 4 transmitters). 9. To exit the transmitter programming/diagnostic mode perform either of the following:
Re: OO Grand Am GT Key FOB
Are you sure you got the right key fob?That will do it and look for numbers on the back of the key fob and call the dealer if it is the right one.Anyway,that proces takes too long and it is quicker with the Tech 2.
I think I have an Impala one. Hopefully the correct one will solve this problem!
I now have correct fob but still never get the chimes - anybody have any ideas! - I think the computer may have been changed. Which one controls the wireless?
Fixed!!! - Replaced 99 bcm with correct 2000 unit and re-sync, alls well. Sure nice to have keyless entry and trunk pop!
