Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 05-30-2009, 12:57 PM
TTodd TTodd is offline
Check Engine Oil Level Light
2000 Yukon XL, Oil changed less than 1000 miles ago, transmission just rebuilt, while driving home from tranny shop, the check engine oil level light came on and has stayed on. Oil level at full, per dip stick. What could be causing this?
Old 05-30-2009, 01:03 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Check Engine Oil Level Light
Since you just had the trans out, I would look at the possibilty of a damaged harness or oil level switch.
The switch is normally open, you can check the continuity of the switch to ground, if it is open, then the wiring might be the problem, if the switch is closed, then the switch is your problem
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
