Go Back   Automotive Forums Car Chat > GMC > Commercial Trucks
Old 05-29-2009, 09:44 PM
gmburd gmburd is offline
1990 vandura 350 auto runs rich
I start my van and it starts to flood and run very rich to where it stalls out.
I started it the other day , ran ok for 5 min and then started to miss and then stall out. I have a manual switch for the fuel pump and by turning it on and off, i can keep it running.
help, Where do I look first/ What controlls the fuel flow?
thanks
Den
Old 05-30-2009, 02:31 PM
maxwedge maxwedge is offline
A990 racer
Re: 1990 vandura 350 auto runs rich
No easy answer here, excess fuel pressure, bad injector, bad coolant temp sensor all can cause this. THE cts is the most common issue here, a scanner would tell you if the pcm temp readings are accurate. If not replace the cts.
Old 05-30-2009, 10:57 PM
patbeechermail's Avatar
patbeechermail patbeechermail is offline
does your engine have a throttle body fuel injection?
Old 06-02-2009, 12:33 AM
update:
yes it is tbi. I took out the injectors and powered them on the bench and sprayed carb cleaner in the pintel. Reinstalled and seems to work fine. Van has been sitting all winter and I ran it for 1/2 hr monthly. Maybe old fuel as well.
Thanks for the replies.
Dennis
