Old 05-29-2009, 09:21 PM
tr10av tr10av is offline
Send a message via MSN to tr10av
Another crazy problem
So I installed a new HU in my 2000 Neon and everything went fine. I'm just a little confused on something I found though. The radio had the standard wiring plug which i connected but there was also another wire apart from the harness (purple/yellow) that was directly connected to the radio. I looked up the wiring diagram and this wire is not on there! I've looked at a few different diagrams and its no where to be found. I asked on some Dodge forums and they don't know what it is either. I don't have a factor amp or CD changer. Anyone have any ideas? Its not really important but since 4 of my speakers don't work maybe this has something to do with it?
'87 Chrysler NewYorker
2 12" Ascendant Audio Assasins in Sealed Box
Hifonics TXi 6406 Bridged to 2 Channels
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 05-29-2009, 09:45 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Another crazy problem
might be part of some security system
Old 05-30-2009, 04:26 AM
Nope. I have the bone stock Neon. no power locks, windows. Just a random phantom wire that doesn't show up on wiring diagrams. Weird huh?
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 05-30-2009, 12:17 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Are you the original owner?
Old 05-31-2009, 12:56 PM
No, but I bought it from the original owner. This isn't some aftermarket wire. It came stock because it has a connector on it that plugs directly into the stock radio.
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 05-31-2009, 05:16 PM
Polygon's Avatar
The Red Baron
You should take a picture of it and where it plugs in on the stock HU.
Old 05-31-2009, 07:27 PM
Audio Guy
a wire for an automatic antenna ? Try seeing if there is some condition that the wire puts out some kind of voltage. If that doesn 't work, plug up the power and grounds to the stock radio and see what it takes to get a voltage from where the wire plugs into the radio.
Old 06-01-2009, 09:31 PM
SaintD SaintD is offline
did your stock radio have a speed sensor to make it louder as your car sped up? my f150 had one that i didn't re use on the new hu.
