Old 05-29-2009, 09:00 PM
faction faction is offline
2001 ford focous Head gasket
I have very little experience with car engines, worked a little helping on hd equipment,
I was just curious if anyone here has experience changing a head gasket on a 01 ford focus, 4 cylinder, pretty sure its a single cam
any other information thats needed just ask
thanks
Old 05-29-2009, 10:03 PM
Mavrick14 Mavrick14 is offline
Re: 2001 ford focous Head gasket
What engine? 2.0l zetech? It's a dual cam motor and its also an interference motor. That means if you don't time the cams correctly, your valves will contact the pistons and your engine will be hooped again. So when you put the head back on with your new timing belt, take some extra care to make sure you line it up properly.
