| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
power window limit switch
got a 2002 cavi. drivers side window goes up too far. replaced the window motor last year. are the limit switchs in the motor? anyone seen this before?
Re: power window limit switch
It goes up too far? I'm pretty sure they stopped making convertible Cavaliers in the 90s, which means that unless I'm wrong about that, it's off the track. There are no switches that limit how far the window will travel, it moves until it hits something. That something should be the top of the door.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
nope, they made convertibles into the 00's
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM, 1981 Fairmont 6cyl 3 speed 1978 Ford Ranchero GT 302 with a few goodies |
its not a convertable. it stays in the track until it gets to the top and pops out and parks itself on top of the aft seal area.
Then most likely the track is bent inside the door, the bottom is probably pushed inboard a bit. Pull the door panel off and see what's going on in there. The top of the window may also be damaged and pushing the glass out, but that would probably be noticeable.
