Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-29-2009, 08:58 AM
joncal joncal is offline
98 Rodeo Starter Issues
My 98 Rodeo started having issues with the starter a couple of weeks ago. When you first turn the ignition it would click once and nothing happened. You could then try again and it would start right away. I was going to check the wiring tomorrow to see if they were loose or corroded. Then today it started fine but when I turned it off the starter kept running and wouldn't stop. By the time I grabbed my tools to disconnect the battery the starter was smoking and so was the positive cable from the battery - it melted the red plastic terminal cover. Anyone else have a smoking starter? What else might need fixin...???
Old 05-29-2009, 05:53 PM
Cat Fuzz Cat Fuzz is offline
Re: 98 Rodeo Starter Issues
Sounds like the solenoid contacts welded themselves together. Time for a new starter.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
