Go Back   Automotive Forums Car Chat > Buick > Century
Old 05-29-2009, 01:35 AM
scottyeric scottyeric is offline
95 Century ABS light on. Cruise not working thermostat gauge not working.
I hope I posted this in the right place.
I have a 95 Century with a 3100. I just bought it with 50,000 miles on it. I love it so far. The only problems I have are that the ABS Light stays on, the cruise isn't working and the thermostat gauge isn't working.
It says in the manual that all of these are on the same fuse but the fuse is good. Anyone else have any Ideas?
Old 05-29-2009, 06:37 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 95 Century ABS light on. Cruise not working thermostat gauge not working.
Welcome to AF!!
The abs light is probably on due to a bad ABS sensor. Unfortunately, like most GM products has a combined bearing and abs sensor. You will need to have the computer scanned with an ABS scanner to see which sensor is bad. As for the water temp guage it could be a dirty sensor. The sensor needs to be removed and cleaned then replaced using a conductive sealant. Once you do this the guage should work again. If not you will need to replace the sensor. The cruise control problem is anyones guess if the fuse is good. It could be in the switch on the column or the pick-up that allows it to function properly.
Old 08-01-2009, 05:33 PM
MSOUTHARDS1 MSOUTHARDS1 is offline
had same problems except temp gauge. sounds funny but i found both thrid brake light bulbs burnt out . i rplaced them 3 months ago problem solved and has not come back .
