Old 05-28-2009, 08:04 PM
flynn12 flynn12 is offline
mpfi
i have a d15b2 in a 88 dx hatch
id really like to do a gsr swap but dont have the cash
so im probly gonna do a mpfi swap from the dpfi
does anyone know of what prices im lookin at?
thanks
Old 05-29-2009, 09:00 PM
readallen readallen is offline
Re: mpfi
75 to 150 w/ used parts - id recommend leaving your stock injector wiring uncut and get more "A" plug pins and run new wires from them, so if you ever needed to go back to dpfi it could be done in flash.
the best thing i have found to depin is a 110/18 sewing machine needle anybody else tryed one
Old 05-29-2009, 09:40 PM
Re: mpfi
aight thanks
yeah i have the injector plugs and a good bit of wire
im just lookin for a d16 manifold now.
Old 05-29-2009, 10:38 PM
Re: mpfi
these
I wasn't referring to the injector plugs I meant the "A" plug to the ecu
just depin and label A1,3,5,7,15 and put some new pins in and go from there
Old 05-30-2009, 08:11 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: mpfi
No sense in adding a new ecu plug, even if you go back to dpfi for some odd reason, just reverse what you did, but usually the only reason some one even attempts to go back is because something went wrong with the mpfi swap lol
A bobby pin works good too at depinning, paper clip also.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 05-30-2009, 06:36 PM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
Re: mpfi
if your looking for parts i have every thing to do this swap about 3 times over from maifolds, to ecus, and dizzys, ect ect, i am in minnesota though so shipping probly isnt worth it
Current cars
1990 honda civic dx High Comp mini me
1986 HONDA CRX SI
Need a winter mobile....
Old 05-30-2009, 07:05 PM
Re: mpfi
Im not suggesting replacing the whole plug, just depin the dpfi pins for the injector wiring and stick in some more pins in their place for mpfi- leaving the original uncut, I like the mpfi and dont want to swap back, but of mice and men, that 40 mpg with dpfi is great even if it is slower.
Old 05-30-2009, 08:12 PM
Tony's Avatar
TLD Member #1
Re: mpfi
Still no need in another plug, just tape up the old DPFI ones if you want to leave them and run new wires all together for your MPFI.
My 2nd mpfi conversion I used a engine harness from a 92-95 civic as my donor. The injectors are actually on their own plug and easy to remove from the rest. I think I'm going to try redoing my white hatch wiring using one of those as well.
Tony
Old 05-30-2009, 08:55 PM
Re: mpfi
i guess u wouldnt necessarily need a whole ecu plug - just 5 pins from it
