Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 05-28-2009, 11:02 AM
afoley afoley is offline
Jerico for GTS
Anyone convert a GTS to a Jerico 5 speed? Apparently they need a different type of Bell housing converter and shifter. Any picks?
Old 05-28-2009, 02:49 PM
eric1h eric1h is offline
Re: Jerico for GTS
Quicktime should have a bellhousing for that, I have one for my LS1 swap and its a nice piece of work!
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 05-28-2009, 03:28 PM
NZGTRA17 NZGTRA17 is offline
Re: Jerico for GTS
A friend has just put a Jerico 5 speed into his C4 vette race car. He had real drama's with getting a bellhousing for this and was told by Jerico that there are no aftermarket bellhousings for the 5 speed (?).
I am pretty sure he ended up having an extra lug welded to a bellhousing he had so that it would take the extra bolt that the 5 speed mount pattern has.
My last car had a Jerico 4 speed in it and that was a really nice box to use in race conditions, well worth the investment.
Kel M
Panoz GTRA #17
New Zealand
Old 05-28-2009, 03:45 PM
Re: Jerico for GTS
Thank you. I called Quicktime and they will have some in about a month, however, after further review i am giving up on the 5 speed and going for hte 4 speed. It apprenetly is a major issue with the five speed and the shifter on the side.
Old 05-28-2009, 03:59 PM
Cobrafang Cobrafang is offline
Re: Jerico for GTS
Give Gary Jones a call. They have put a Jerico in a GTRA on an awesome 347 stroker. They had to fab a new tunnel to accommodate the linkage. They would be a great source on knowledge on getting them in our cars.
706-592-0060
-Cobra (A.K.A Tom D)
Racer and Gamer
Panoz GTRA (Mystery Chassis #) (Track Toy)
2001 BMW M5 (Road Toy)
2006 F250 (Car Hauler)
2002 Odyssey (Kid Hauler)
Old 05-28-2009, 04:11 PM
Re: Jerico for GTS
I have to tell you guys...this is the first time I have used this sight and I am floored at the knowledge and help you get here. Thank you.
Old 05-28-2009, 04:16 PM
Re: Jerico for GTS
This really is a great site and some smart guys, I'm just not one of them ;-)
Old 05-28-2009, 05:03 PM
Re: Jerico for GTS
Another box you may want to consider is a Tex Racing T101. These have become very popular over here as they are a little easier to work on than the Jerico and have a main shaft mid support bearing as standard. Also seems to be more used T101 parts listed on E Bay so may be cheaper to 'feed' in service..........
I found the Jerico to be very robust and never broke it but I have seen plenty of broken Jerico's and T101's. Pays to crack test the gears every season if you have a reasonable amount of torque as this is the killer. Also highly recommend using a Long shifter on the Jerico. A nice unit that is extremely positive to use.
Hardest thing I found when looking for a used Jerico was getting one with Road Race ratios and not circle track ratios. In the end I bought a good used Circle Track unit and swapped the ratios over which worked out OK.
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 05-28-2009, 08:34 PM
panozracing's Avatar
panozracing panozracing is offline
Re: Jerico for GTS
robertson racing converted a GTS as well. They sold that car to wirewheel so he might have some info too.
