Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-27-2009, 08:35 PM
VividVisions VividVisions is offline
'97 eclipse sypder water pump
looking to get some tips or hints on how to remove the water pump. all the searches i have done are for the passenger side location but this motor is on the drivers side. or its for a DOHC. looks like i need to pull the crank pulley then the plastic cover?? what kind of tool is needed to get the center bolt out of the pulley? whats the torque spec? any help would be appreciated.
V.V.
Old 05-27-2009, 09:12 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: '97 eclipse sypder water pump
I would suggest you go buy a shop manual from the store. They aren't expensive and will come in very handy when workin on the car. It should have everything your looking for in there.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-28-2009, 09:23 AM
not my car, don't know if i will ever work on this car again. and past vehicles its real nice to come on these websites cuz u can read of another person trying to save 16 bucks and do it himself without a manual. thanks tho
Old 05-28-2009, 11:35 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
easy, pull the timing covers, and the ps/alt belts... TDS the engine, and pin the timing tensioner, and slip the T-belt off the cam gears. remove the water pump, then do whatever you need, and put it all back. have fun with out a manual. good luck with torques... ;-) i wish you the best.
