Go Back   Automotive Forums Car Chat > Ford > Club Wagon
Old 05-27-2009, 02:37 PM
cybercytes cybercytes is offline
E-Series Van 1992-2007 front-right exterior door handle removal?
replacement handle fits 1992-2007
inside door panel is removed
locking mechanism is visible
handle mounting rivets are drilled out
handle is loose
How do we disconnect the handle linkage???
NOTE: the handle cannot be pulled through the opening until the linkage is disconnected.
Old 05-27-2009, 06:31 PM
rhandwor rhandwor is offline
Re: E-Series Van 1992-2007 front-right exterior door handle removal?
http://powervisionmirrors.com/ford/f...nuals/8510.pdf
Old 05-27-2009, 06:37 PM
Originally Posted by rhandwor View Post
That's great for removing mirrors...doesn't do a thing for removing exterior door handles.
Old 05-28-2009, 08:09 PM
Disconnect rods to electric door lock actuator if equipped. Should be a plastic piece behind door handle. Use a screwdriver pry out with screwdriver should be a slot. Should have torx type fastener.
