stuck in 4 low
Hi all my 96 1/2 ton is stuck in 4 low it has the push buttun on the dash i went to put it up on the ramps today so i put it in 4 hi and the lite dident come on, so i dident think to much about that so when i went to go up the pamps i noticed it was in 4low so i pushed the butten agen and it stayed in 4low no sound nothing
any help?Thanks jm |
Re: stuck in 4 low
you where running this vehicle in 4wd low or it by itself went into 4wd low ...? |
Re: stuck in 4 low
donno about 96 model, but it takes several buttons to be pressed same time to disengage 4LO on 2000 model. you sure you do it right?
Re: stuck in 4 low
I had this happen with a different chevy with electronic selectors. I was stuck in 4 low, so I drove it a few miles, at 25-30 miles an hour, then put it park, switched the buttons, turned it off, then tried it again and it switched. The push button is nice to have, but I don't mind the mechanical.
Re: stuck in 4 low
Did you try puting the tranny in neutral and then pressing the button?
Re: stuck in 4 low
Re: stuck in 4 low
like what was the problem with that transfur case motor...
Re: stuck in 4 low
My 2000 Z71 did that but eventually i got it to go back in. My four wheel drive wasn't working. Took it to the dealership and the mechanic said he just cleaned the grounds because they were a little rusted. Fixed it and now it works perfect.
