Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-25-2009, 07:13 PM
ghard000 ghard000 is offline
96' dodge Ram 2500 4x4 front axle
I have a Dana front axle in my Ram 2500. I'm trying to replace the seals. How do you remove the carrier unit from the axle housing? I have removed the two caps and pulled the axles out but I can't seem to get the unit to come loose.
Old 05-31-2009, 07:43 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 96' dodge Ram 2500 4x4 front axle
As far as I know, the Dana 60 carrier should pull straight out, I'll do some checking tomorrow.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 06-05-2009, 11:05 PM
hundahunta hundahunta is offline
you need to pry it out, usually you need to install a spreader but not many people have one.
Old 06-06-2009, 07:38 AM
angus10 angus10 is offline
You did also remove the intermediate axle shaft too correct?
98 Ram 1500 4x4
Flowmaster American Thunder W/super40
