Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 05-25-2009, 06:08 PM
cook4444 cook4444 is offline
will not start with the key
90 beretta starter works purple wire has power at starter .But the key will not start the car.Tried to start it in every gear.But do hear a clicking sound over top of the glove box.? Any ideas on where to look now???
Old 05-27-2009, 08:00 AM
rhandwor rhandwor is offline
Re: no start
I would clean the battery cables and try again. If its started Auto Zone or Advanced will check the battery and starter free.
Old 05-27-2009, 08:45 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: no start
Try starting it in neutral.
Check the purple wire (its usually purple) at the starter for power when the key is in the crank position. If there is no power (I suspect) you'll need to work your way back through the neutral safety switch and back to the ignition switch.
Old 09-15-2009, 10:50 PM
loosenut74's Avatar
loosenut74 loosenut74 is offline
Send a message via Yahoo to loosenut74
Re: no start
You need a new starter.
Removed by Moderator
