Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-25-2009, 12:09 PM
paulXnoob paulXnoob is offline
RPMs ticking then car dies??
Whenever I drive my car around it starts out normal. Then after driving it for a little bit the needle on the tachometer will start to dip and rise very sporadically. It does this mildly in the begining until the needle starts going up and down very violently and the car dies (it always manages to be on a main road -_-). I don't know where I would even begin to look for the problem, any ideas or similar issues??
Old 05-25-2009, 11:29 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: RPMs ticking then car dies??
What car and motor? It would be helpful if you put your car and all its mods in your sig.
So the car does this while your sitting at idle? Or when your driving down the road to? Auto or manual trans?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-26-2009, 12:17 AM
Its a 98 eclipse gs, 420a motor, manual 5 speed. It dies whenever it feels like but specifically at the lower rpms
Old 05-26-2009, 06:48 AM
Holset powered 420a
Do you have a check engine light? Have you changed the plugs, wires, etc. lately? I would also test the IAC motor. Will the car run if you keep tapping the throttle?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 05-28-2009, 11:03 PM
Yes when it starts stalling the check engine light comes on. I recently took the plugs out to clean them but I didn't replace anything. Yeah the car will stay alive if I keep giving it gas. I changed the air filter a few days ago and that seemed to help...today I took out the throttle body and it was completely covered with black soot..I also took out the intake manifold and gave them both a good cleaning...I got the intake manifold back on but I need a throttle body gasket before I can finish putting everything back together. Hopefully that will help. I found the IAC and cleaned it off a little but how would I get it tested? Thanks for the advice!
