Old 05-25-2009, 07:02 AM
mkehayias mkehayias is offline
1998 2.2L quit running
I bought it used three weeks ago. Plugs, wires, oil, filters, serpentine belt, tensioner, and all brake parts at the wheels changed.
Two days ago the check engine light came on. Yesterday, traveling at 65 mph, the car just quit running. I disconnected the battery leads and shorted them together, the car fired up, travelled 40 feet and died again. No other symptoms, just died. Now the car won't fire up.
Car has plenty of oil. No overheating. The only other thing wrong is two front tires that are out of balance, they cause the car to vibrate badly above 45 mph.
Is there a procedure to read OBD codes without a reader? Is there a specific procedure to reset the ECM/ECU? Where is the ECM/ECU located? Anyone had this same problem? Thanks.
Old 05-25-2009, 09:05 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 1998 2.2L quit running
"resetting the PCM" will do you no good! You need to find out what you are missing in order to go any further. A vehicle needs spark, fuel, and compression to run. Which one are you missing? Find this out and there will be a wealth of responses on what to do next.
Finding out what the code(s) are will also help narrow done the potential problems. You will need an OBDII code reader to do this.
My money is on either a crank sensor/module (no spark) or a fuel pump (no fuel pressure). You should be able to hear the pump run for a couple of seconds when you turn the key on?
Old 05-26-2009, 04:57 AM
I beg to differ, resetting the pcm and being able to move the car ruled out the timing chain and gears and a plethora of other potential mechanical problems as the cause.
Troubleshooting is an elimination game, I have eliminated the engine as a failure source, as well as reduced the probability that the fuel delivery system failed.
I can hear the fuel pump when I turn the key on. Are you saying there is no process to obtain the codes without a reader (one of the four questions I asked)?
BTW, you left out air when you were listing the things the engine needs to run. You may find "suck (intake fuel/air mix), squeeze (compression), bang (ignition/power), blow (exhaust)" useful to help you remember the four cycles of the internal combustion engine.
Thanks for your response.
Old 05-26-2009, 02:08 PM
Airjer_'s Avatar
It likely would have started whether or not you "reset" the PCM.
You will need a code reader to read codes.
Compression, spark, fuel If your missing one of these than the others don't matter
I am well aware of how a four stroke engine works! In fact if your vehicle was sitting in front of me I would have had it diagnosed and running about 30 minutes after you made your first post. So in a way "experience" should be added to the three things an engine needs to run?
Old 05-26-2009, 02:57 PM
Well, like the full gas tank, 35 years experience should be enough. I posted this because I am not familiar with the vehicle's engine control system, and hoped to save myself a lot of trial and error fixing the problem, which I will do.
I am not here to get into a "mine is bigger than yours" posting contest. Please feel free to not reply in the future. Manners, like experience, are gathered over time...
Old 05-26-2009, 05:33 PM
J-Ri's Avatar
J-Ri J-Ri is offline
If you are not familiar with the engine control system, then you shouldn't be dismissing the suggestions of someone who is. Airjer said 100% of what I or any automotive technician would have said. That said, I also feel free to not reply, because my advice will be just as "useless" as his. One may also say that having good manners would imply that when asking for help that you thank anyone kind enough to reply and just not do it if you think it's wrong. We don't get any sort of financial compensation for helping someone here, and if anything it costs us money because chances are that eventually we will help someone who would otherwise bring their car to us. I wish you the best of luck in this, but since we apparently don't know what's going on, you'll probably be on your own since after what you said nobody will be inclined to chime in.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 05-26-2009, 10:46 PM
Airjer_'s Avatar
Did you look to see if you have spark?
Old 05-27-2009, 05:28 AM
Even though I could hear the pump run I wanted to make sure the fuel delivery system was working. It may sound useless, but I have had two issues 0n other cars where the pump ws good but the engine was not getting gas, so last night I confirmed that fuel pressure was good all the way to the injectors. I disconnected/reconnected lines starting at the fuel pump and working to the engine, the pressure and flow are good. Tonight I start on the ignition, starting at the plugs. Will running a jumper from battery to coil work on this system? I have done this on other cars to bypass the Engine Control system and verify the primary ignition system. I have not done it on a vehicle with an ignition module such as this.
I am also concerned that water intrusion or vibration may have affected the ECM. I am going to look at the connectors to make sure they are ok. If anyone knows where the unit is located, I would appreciate that info.
Thank you for your response A, I will post what I find later this evening.
Old 05-27-2009, 08:40 AM
Airjer_'s Avatar
Do yourself a favor and get a spark tester. Test each plug wire at the plug. You can do this with a test light also. Two things that should be in every toolbox.
Also crank it over a couple of times and pull a plug. Are they wet with gas?
The computers are pretty tough and are rarely the problem. In the last 15 years or so I have had to replace a handful.
Old 05-27-2009, 11:14 AM
Thanks Airjer_, I have both in my toolbox, (actually have 4 spark testers, I am lazy, I hook them all up at once). That is my plan for this evening. I appreciate your comments on the module, I will not worry about it for now.
Thanks for your suggestions, I will post back after I get done testing.
Old 05-27-2009, 05:01 PM
No spark at any plug. Plugs are wet (I could smell fuel before I took them out, but...).
Old 05-27-2009, 08:37 PM
Finally got my hands on a code reader, here are the three that were stored in order:
P0141 O2 Sensor Heater Circuit Malfunction
P0300 Multiple random misfire
I cleared the codes, cycled the ignition key, no new codes, cranked the engine, no new codes.
The O2 Sensor is shiney new.
I also noticed that the Theft Protection light never goes out, is it supposed to and when?
I don't feel like the codes are helping. Any ideas are appreciated.
Old 05-27-2009, 10:50 PM
J-Ri's Avatar
I said I wouldn't, but here goes. I was in a bad mood that day to begin with, no hard feelings
Did the code reader give P0141 twice or was one omitted?
The security light should go out after the bulb check, staying on means that the security system is active, which I believe on yours cuts the fuel injectors. Testing it may have triggered the theft system if you cycled the key too fast or too many times. To reset the system, try to start the car, then release the key to the "on" position and wait about 10 minutes. After 10 minutes the light should go off. Try to start the car again and release the key, the light should be off now.
If your car has a tachometer, make sure the needle lifts off of 0 while cranking. If you don't have a tach, you'll need a scan tool capable of reading the engine RPM. If either reads 0 it means the CKP sensor signal isn't seen by the computer. The spark timing is based off of the CKP. The fuel injector signal is also based off the CKP sensor so the fouled plugs probably rule this out, but I prefer to check everything that could cause the problem. It's easier for me to check everything with the scan tool first, but lacking one, you may want to check the ignition module for signal in and out first.
Old 05-27-2009, 11:28 PM
Airjer_'s Avatar
agreed!
Old 05-28-2009, 05:15 AM
Thank you both for replying!
The codes are in the order that they appeared on the reader. I thought it was odd that the oil sensor was in twice, I figured the that at least the first one was old. The tach lifts off zero and the plugs are wet. After cranking it a few times there is a serious fuel smell as well, I am leaning away from gas starvation but of course have not ruled it out...
The theft system light is on steady and does not go out. I tried the 10 minute reset with no luck. I will try it again today just to make sure I gave it enough time. Is it possible something got shook loose?
I am glad you both chose to reply, your advice and knowledge have been a great help. There is no way to convey it here, other than to say I really appreciate your time.
I will post back what I find this afternoon.
