Old 05-24-2009, 02:01 PM
strunch strunch is offline
Intermittent blower
I replaced the blower and blower resister on my 99 astro van last year and it has worked fine. However recently the blower quit and then turned on by itself after I restarted. It worked fine for a week and then went off again. I popped the hood and tapped it with a hammer and it kicked in. I understand blowers wear out but I replaced it only last year. The van was sitting for six months unused. Is this normal? Did I just get a bad blower?
Old 05-25-2009, 02:22 PM
CD Smalley CD Smalley is offline
Re: Intermittent blower works when I tap it
Time for another new one in my opinion. They should last longer than that. But it depends on the manufacturer.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 05-26-2009, 05:40 PM
It stopped working again today and tapping it didn't help. When I got home I checked the voltage between the black and red wire coming from the blower resistor. It only read .2 volts. So I plugged it back into the fan and spliced into the ground wire coming out of the blower and routed to the chassis. This resulted in the blower working on all speeds except high. This leads me to think I have a grounding problem somewhere....or a problem with the blower resistor itself. Any clues where to look next? I'm still working on pulling the plastic reservoir out so I can get a better look.
Old 05-26-2009, 07:13 PM
I found the problem here. I filed off the carbon and everything works now. I wonder what caused this short?
Old 05-26-2009, 08:29 PM
brcidd's Avatar
brcidd brcidd is offline
That is NOT a short- it is arcing from a bad connection- when two connectors are together, they must touch cleanly, without corrosion, if there is limited connection, then heat and arcing is generated-- ever touch a blower hot lead to a battery- you see flashes, or arcs-- this is the same thing- except it is continuous- then it melts the plastic around it...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-26-2009, 10:00 PM
Smile Re: Intermittent blower works when I tap it
ahh i see. It's amazing the chaos a bad connection can create. I'm just happy it was a cheap fix.
Old 05-27-2009, 05:46 AM
There is a gel you can get to put into those connectors to keep the corrosion from happening. Looks like you could use some.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 05-27-2009, 07:36 AM
brcidd's Avatar
Yeah- the gel I use is Dialectric grease- sold at parts stores everywhere...
'99 GMC Yukon
Old 05-27-2009, 12:12 PM
That's it! Couldn't think of its name at 5:45AM.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
