Old 05-24-2009, 12:32 PM
shadetreeric shadetreeric is offline
99 caravan belt tracking to inside
have a 99 dodge caravan... had pwr steering pump replaced and they said had to replace pulley ..... belt started tracking to inside of tensioner... removed and replaced tensioner and pwr sterring pump unit again and still tracked to inside... have removed and tried different things. finally put a spacer behind unit where power steering had bolt that fits into bracket off of the block and got belt moved over about 3/16 inch i guess my question is do i need a longer shaft on pwr steering unit or can pulley be pressed on a shorter distance??? the belt is not riding off of the tensioner but. is only on probably 1/32 of an inch... tks
Old 05-28-2009, 07:30 PM
Re: 99 dodge caravan
well i probably did not splain myself right on this caravan has anyone ever had problems with belt tracking and shredding to inside of tensioner after replacing power steering pump? tks
Old 11-06-2012, 09:01 AM
70165 70165 is offline
Yes I appear to be having the same problem. Did you find a solution? Thanks.
Old 11-06-2012, 01:02 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Based on the dates and looking at his history, Shadetreeric may not be around anymore. His last post was June 09. All I can suggest is to use an OEM pump.
If you don't get any help here try Chryslerminivan.net
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
