Old 05-24-2009, 10:53 AM
BoB393's Avatar
BoB393 BoB393 is offline
Interior door panels
Has anyone removed the interior door panels from there 94/95 LeSabre? I'm trying and not having any luck.
I could sure use some help on this before I break something. It appears that all the fasteners are hidden
except the one by the door latch and that only removes the cover plate for the power door locks.
Old 05-24-2009, 05:06 PM
spinne1 spinne1 is offline
Re: Interior door panels
You first remove the door handle trim with (one small torx.) Then you put a flat head screwdriver at the front of the power window black piece and put down in between the arm rest and the piece and gently push the screwdriver forward. This releases the catch and you can pull up the power window piece from the front first and then slide forward. Remove the wire harnesses and set the power window piece aside. Next, unbolt the two 10mm bolts in the space you just opened up. Next, pry off the reflector at the back of the door panel near the jamb area by pushing a small screwdriver above the top of the reflector and pushing down while pulling back on the reflector. This reveals two more 10mm bolts. One straight in and one 90 degrees to you and facing the outside of the door. After this it is simply a matter of popping the plastic holders with a panel removal tool (they sell the kit with this tool for $10 at Harbor Freight.)
Old 05-24-2009, 08:42 PM
BoB393's Avatar
Perfect!
I saw the torx and was sure that would revile the rest of the bolts, but NOoo, only the door lock. I also saw the 1 10mm straight inside the reflector in the back.
I missed all the rest. And I never would have gotten the clip on the power window trim piece.
Thank you.
Old 05-25-2009, 03:21 PM
BoB393's Avatar
Thanks again,
They came off without a hitch!
