Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-23-2009, 10:50 PM
ghockey216 ghockey216 is offline
99 sl2 ABS light
Is there a fuse that i can take out or something that will turn off my ABS and Parking Break lights off?
Old 05-23-2009, 11:24 PM
RC1488 RC1488 is offline
Re: 99 sl2 ABS light
Why not fix it?
The parking brake light is on for :
a) low fluid pressure
b) emergency brake is on
c) ABS Module indicates error
d) HYDRAULIC FAILURE POSSBILE
Bc your abs light is also on, its more likely option c. BUT i would not risk it. FIX THE ISSUE
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 05-23-2009, 11:44 PM
I know that the ABS module is not working i have had my uncle get the codes and found that it is the ABS module is broke. I dont have the money to fix it so i was wondering if there is any way just to turn the lights off.
Old 05-24-2009, 05:19 PM
Magevro Magevro is offline
I had the same issue. The ABS and parking break would always be lit, but the ABS and my brakes as a whole worked fine. It started right after I changed my front brakes, and I was told that it probably meant I didn't bleed them properly, or that I might have hit the sensor.
Old 05-25-2009, 01:54 PM
Usually the ABS Sensors are dirty at the spindle. I have yet to see an ABS Module that is actually bad. 9/10 times its just dirt in the sensor or the reluctor ring.
