Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 05-23-2009, 03:03 PM
supercamaro supercamaro is offline
Question head gaskets installed now runs rich and stalls
I just replaced head gaskets on my 97 transport runs good after it warms and at low idle like coming to a stop, it stalls starts right up and runs fine for a minute I pulled into the drive way and let it run at idle for about a minute and it stalled with no codes showing and no lights on smells rich. Did i mis something??
Old 05-23-2009, 10:42 PM
roadrunner2 roadrunner2 is offline
Re: head gaskets installed now runs rich and stalls
Check that the IAC valve is tight and the electrical connection is good and/or the valve is clean.
If that's good then I would clean the throttle body.
There MAY also be a loose or disconnected vacuum hose.
The problem with doing nothing is not knowing when you're finished.
