Old 05-23-2009, 02:56 PM
dballowe dballowe is offline
1990 S10 Code 42 & 44
I have a 1990 S-10 2.5l FI 2wd. It starts and runs fine for a while. Then starts jerking and bogging down till the check engine light comes on. Then it runs fine. The light almost always comes on going up a hill. When the light goes off it starts running crappy again. I am getting codes 42 & 44.
Thanks for any help.
Old 05-24-2009, 08:44 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1990 S10 Code 42 & 44
Code 44 is lean exhaust.
Code 42 is a short or open to ground in the HEI-EST or bypass circuit.
Does both codes come in same time?
MT
Old 05-24-2009, 10:19 AM
Re: Code 42 & 44
Not sure. I will clear the codes and then check it again after the light comes back on. Is that the right thing to do?
Old 05-24-2009, 11:47 AM
MT-2500's Avatar
AF - Advisor
Re: Code 42 & 44
Yes that is a good start.
But if either code comes back get a good repair manual and go threw the repair flow chart for that code.
On the lean exhaust code make sure the fuel pressure is up tp par and check fuel filter.
MT
