Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 05-23-2009, 12:52 PM
wilkerson3 wilkerson3 is offline
Rear Blower
My '99 Montana rear blower is not working. I have control of the rear audio panel. Neither the rear controls on the front dash work nor the controls in the back of the van. I just replaced the resistor to get my front controls to blow at the 5th speed. (Thanks to the advice here on the forum.) I checked the fuse for the rear controls and it's ok. I don't get heat or A/C. Is there a seperate rear blower I need to check? Could you direct me to where it is housed?
Old 05-23-2009, 11:38 PM
roadrunner2 roadrunner2 is offline
Re: Rear Blower
The rear blower motor is usually housed behind the left rear panel.
Have you got power going from the (rear blower) dash switch toward the rear? If not, try bypassing the switch and see if the blower works.
Do all the front blower speeds work? You said you replaced the resistor for the 5th speed.
The problem with doing nothing is not knowing when you're finished.
Old 06-15-2009, 10:35 AM
Re: Rear Blower
Got it. Thanks. Blower motor was bad and just replaced it.
Old 06-28-2009, 11:57 AM
Rodc Rodc is offline
Re: Rear Blower
Wilkerson3, please elaborate on how you replaced the blower. What had to come apart and how did you get at it?
Many thanks
