Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 05-23-2009, 11:30 AM
timbob_45 timbob_45 is offline
96 A4 2.8 headlights
HI everyone,
I have a 96 A4 and the head lamps would intermittently stop working. More specifically the low beams, high beams, and foglamps all were inoperative flash to pass however did work. I diagnosed it as a headlamp switch issue. I installed the new switch and now I have low beams and fog lamps but no high beams or flash to pass. I was able to supply battery voltage to the high beam circuit at the switch connector and light up the high beam bulbs so I think I have another bad switch. Any other ideas would be appreciated.
Old 08-13-2009, 03:13 PM
samsyabi samsyabi is offline
Re: 96 A4 2.8 headlights
Check the wiring too. Maybe it is happening due to some cut.
Audi Q7 2008 Audi Performance Chip
Old 08-30-2009, 09:33 PM
audiengine's Avatar
audiengine audiengine is offline
Sounds like your ground wire might be lose, try re-attaching it.
Old 12-28-2009, 01:43 PM
ExTrEmEDrIfT's Avatar
ExTrEmEDrIfT ExTrEmEDrIfT is offline
Send a message via AIM to ExTrEmEDrIfT Send a message via MSN to ExTrEmEDrIfT Send a message via Yahoo to ExTrEmEDrIfT
nevermind..
Past Z Car Crew
[The Enemy Of Your Enemy is Your Friend]
>>Keep Your Friends close : But Keep Your Enemies Even Closer <<
