Old 05-22-2009, 10:30 AM
nishant.89 nishant.89 is offline
Send a message via Yahoo to nishant.89
steering ratio..
Can anyone there tell me the different ways for lowering the steering gear ratio of my end take off rack and pinion steering having ratio of 18:1.
Old 05-22-2009, 06:01 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: steering ratio..
The quick and dirty way is to see if you can find spindles with longer steering arms. The same input from the rack will cause less steering angle.
Dragging people kicking and screaming into the enlightenment.
Old 05-24-2009, 05:10 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
I may be misinterpreting the question, but isn't that 'shorter' arms?
From my interpretation of the OP, "lowering" the steering ratio means that he wants to quicken the steering effect, so less steering wheel motion is required to turn the front wheels.
Old 05-25-2009, 08:28 PM
curtis73's Avatar
Depends on what he means by "lower".
Shorter steering arms will cause quicker turning in effect lowering the numerical ratio. Longer steering arms will cause slower turning in effect lowering the amount of steering.
If he wants to reduce the numerical ratio, then yes, shorter arms.
Old 05-25-2009, 09:32 PM
any other method to quicken the steering ratio?
