Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-21-2009, 06:02 PM
blackEyeSSFly blackEyeSSFly is offline
Removing engine...
Have not attempted this yet...How hard is it...in reality is it a two man job...I have done my research and its something i think i can do on my own...I need to remove the motor to install a coolant steam pipe...the guy who did my 4.3 to 5.7 swap neglected to put this part on..any suggestions or tips from the everyday engine removers...
Cardomain http://www.cardomain.com/ride/2143750
Success is to be measured not so much by the position that one has reached in life as by the obstacles which he has overcome
Old 05-22-2009, 05:47 AM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Re: Removing engine...
my father did an engine swap all by himself not too long ago...so yes it is possible to do it yourself, but it does help to have another person. just make sure you rent a good engine lift
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 05-22-2009, 10:01 AM
j cAT j cAT is offline
you mention a coolant steam pipe...since this needs replacing I would get another opinion on this......
removing the engine to replace a componet is not the norm...
Old 05-22-2009, 10:28 AM
rhandwor rhandwor is offline
If you have a used part from a junk yard post a picture as I think J Cat is correct that it can be installed with the engine in the car.
