Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 05-20-2009, 11:00 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
Cost to Convert to Carb
I recently converted my GT-RA to carb and I thought some guys may want to have a list of what's involved and the price. I got most of the stuff through Summit. The one key is the Aeromotive regulator which allows you to use the efi pump with the carb. It regulates an EFI pump down to the pressure needed for carb. Works perfectly.
AEI-13204 Aeromotive “EFI to Carb” Fuel Pressure Regulator - $155.95
FPP-1250 Fel-Pro Intake Manifold Set - $22.95
MSD-6421 6AL-2 Ignition Box - $251.95
MSD-8223 Blaster 3 Power Tower Coil - $40.95
MSD-8598 Billet Distributor - $239.95
WND-8020 Weiand Stealth Manifold - $159.95
Ford Spark plug wires $45
Misc Fittings / hose - $140
Gauges (Sport Comp)
ATM-3327 2-1/16” Oil Pres 0-100 PSI Electric - $59.95
ATM-3337 2-1/16” Water Temp 100-250 Degrees - $45.95
ATM-3348 2-1/16” Oil Temp 140-300 Degrees - $45.95
ATM-3391 21/16” Voltmeter - $39.95
Tach (already had) ~ $200
Panoz GTS throttle linkage assembly - $275
Carb – Barry Grant Speed Demon 650 (already had) - $450
Air filter - $75
Oil / Coolant - $50
Total cost: ~$2300
Tips:
The 5" Monster tach is the perfect size for me and mounts right to the steering shaft with a clamp. I had to trim the bracket that mounted this Pi display.
I had to make a gauge panel for the gauges. When you pull the efi stuff out of the car you'll end up with several usable OEM quality plugs. One has 8 wires on it and I used it to wire up the gauges so when I need to pull the main panel I can just unplug the gauges and remove it as one piece - like normal.
I'm glad I did it. The Weiand Stealth intake is a good piece. I need to play with carb jetting since it was setup for a much higher hp motor but the feel of the car is going to be right. I was worried about throttle response / feel and I no longer am.
I'll take a few pictures when I get a chance. I really pulled a bunch of "junk" out of the car...
Jim McGovern
~ Building 289 Lemans Replica
~ '92 Mustang Coupe: 347ci / Carb
Pictures
Old 05-21-2009, 09:20 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Cost to Convert to Carb
Yeah... all said moving to aluminum heads and the carb saved us about 150 pounds when you look at everything that was removed.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 05-21-2009, 09:26 AM
eric1h eric1h is offline
great thread! I wish I had seeen the EFI to Carb regulator before I went out and bought a new carb pump! lol
Although, I used a "Holley Red" internally regulated pump(to 7psi) and it was only $120
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 05-21-2009, 09:27 AM
To add to that.............the Holley red only pumps to 7psi, which cuts down on the heat in the fuel/ lines from the added pressure of the high pressure pump, supposed to be good for a few extra HP!
Old 05-21-2009, 10:19 AM
Cobra4B's Avatar
Yeah I was informed that it was more durable to switch pumps vs. regulating the EFI pump, but who knows if that was just them trying to sell me a new pump.
Old 05-21-2009, 07:14 PM
jmimac351's Avatar
I've heard just the opposite. There is a return line and the system is seeing 6lbs of pressure. I would think the EFI pump is seeing very little strain since it's designed to operate at much higher pressures. There is a lot of fresh fuel flowing through the line and back to the tank. On my cobra I have a Holley blue with no return line. I'm pretty sure the fuel in the cobra is hotter although it's never been an issue.
Jim McGovern
Pictures
