Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 05-20-2009, 09:49 PM
skipper1383 skipper1383 is offline
Loud noise under hood at startup
I have a 2001 Lincoln LS 2 Door V-8 with 66,000 miles. When starting the car after it has not been started for a couple of days there is a loud noise similar to a "backfire" from the left side under the hood. The car will then start and run normally.
Old 05-21-2009, 06:33 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Loud noise under hood at startup
Welcome to the forum!
Noises over the Internet are one of the most difficult things to diagnose, therefore requiring a lot of description.
First off, when you say "Left side" are you referring to as looking at the engine from the open hood (passenger side) or from sitting in the car (driver's side)? Have you been looking under the hood when the noise occurs? If so, does the engine do anything odd when the noise occurs, such as shake abruptly? Does the noise occur as soon as the starter engages, or is it after a revolution or two of the engine? Does the enhaust smell odd? Are there any diagnostic codes? Has the fuel economy changed recently?
-Rod
Old 05-22-2009, 05:54 AM
Thanks for responding!
The noise comes from the drivers side and occurs as soon as the starter engages. I have been looking under the hood when this occurs and did not see an engine shake or notice an odd smell. I have not noticed a change in mileage either. I had been told it may be due to a faulty coil on one of the cylinders but there are no engine codes and the car seems to run ok.
Thanks
Old 05-22-2009, 06:57 AM
shorod's Avatar
SHO No Mo
If a faulty coil, I would expect the exhaust to have an odd smell and, as you mentioned, you'd notice it when having the engine under load. I wonder if there's something loose in the starter motor since it sounds like that's the only time you notice the sound.
-Rod
Old 01-07-2010, 09:47 PM
aleutian aleutian is offline
There is a TSB about a snapping sound when you start the LS when it is colder out. Sounds like metal slapping a few times and stops after it warms up a few minutes. This is caused by the belt tensioner pulley. This might be your issue. hope it helps.
