Old 03-31-2003, 12:12 PM
91civicDXdude's Avatar
91 CRX Si Rear Discs on 91 Hatch........
I just got the deal of a lifetime... an entire rear disc conversion kit for $50 :P :P :P
I was just wondering if the factory civic brake lines will work? I know i have to get the ebrake cable from a 90-93 teg as the CRX one is too short, but what about the brake cables? can i use my factory civic ones??
I know plenty of you have done this swap, so help a brotha out.
btw, I passed up another deal, I was going to get the rear disc conversion AND 2 IMMACULATE CRX SI SEATS....all for the low price of $125. then i found out that the crx seats didnt bolt in to my car so i passed it up. :S Thinking i might go ahead and buy them and sell them on ebay for lots more
Old 03-31-2003, 12:17 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
You need 90-93 Integra Coupe brake cables.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 03-31-2003, 12:18 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
CRX is too short. when the rear disc was put on the si the parts came off the 90 integra we had. *yes that teg ended up being a special limited edition with rear drums*
since all there was to work with were the 2 cars parts the teg kept it's e-brake cabel and the si the same. expect the crx cable to be too short. if you can get your hands on the teg cable, to it to it. if not, i know you can make yours work. you're handy dandy with the mechanical skills
word of advice! get some corks for the brakelines. we forgot. some quick thinking i covered the lines with clingy plastic wrap (folded it many time to make it thick) and put a rubber band around it. it worked....but corks would be much more easy
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 03-31-2003, 12:20 PM
Corks for the brake lines? What does that mean?
Old 03-31-2003, 12:22 PM
amy@af's Avatar
well...when you take your stuff apart you don't want brake fluid everywhere......and empty brake lines. so you need to cap it off. small corks work best
Old 03-31-2003, 12:24 PM
are you meaning brake cables as in the ebrake cable or the brake lines as in the lines that the brake fluid travels through??
If i can get away with using the civic stuff i will and i'll probalby put them on today or tomorrow, but if i need new brakes lines it will have to wait..
Old 03-31-2003, 12:30 PM
amy@af's Avatar
e-brake cable. still have the si e-brake cable....and the teg still has it's e-brake cable. generally i wouldn't tell just anyone to do it to it. but i know you are mechanically set
i wasn't trying to confuse you by throwing in the cork and brake lines. its something we forgot....so i thought i would give you a heads up. then again, maybe you like to play with plastic wrap and rubber bands :silly2:
Old 03-31-2003, 12:32 PM
awesome. thanks yall
Old 03-31-2003, 08:57 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
SPECIAL MESSAGE FROM AMI:
"for whatever reason i can't get on AF.....been trying for 3-4 hrs . i need to take back what i said earlier. when the brake conversion was done i had a broken foot. the only part i touched was the stupid break lines leaking. i doubled checked with jer. I WAS WRONG. apparently the teg has the si e-brake cable and vice versa. so YOU WILL NEED TEG E-BRAKE.
i greatly apologize for the misunderstanding. i wanted to be sure that was cleared up A.S.A.P."
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 04-01-2003, 08:04 AM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
ok here is the deal:
E-BRAKE
for a CIVIC HB - 90-93 2door e-brake cables
for a CRX - u will need CRX SI (90-91) cables
for a 4d- u will need 90-93 teg 4d cables
Brake line
For a CIVIC HB- CRX Si (90-91) brake lines OR 90-93 teg
for a Crx- SAME
For a 4d- SAME
side note- some places will not sell you used brake lines do to the risk of having them break on you and u sueing them so u might want to invest in some goodwrench stainless steel braided brake lines they are VERY high quality and they are worth EVERY penny and they last way longer than stupid ruber ones
make sure u get the lower LCA arm for the rear sway bar and pick up the rear sway bar while ur at it. it makes a HUGE difference
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run???
BLU CIVIC- no...it doesn't have any legs
Old 04-01-2003, 08:15 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Hmmm..so when I want to do the 90-93 Teg rear disc swap onto my sedan, I'll need the e-brake cable from an Integra sedan???
That sucks..I have a 91 Integra coupe at the junkyard, just begging me to pull off its rear discs..I won't bother with the cable
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 04-01-2003, 12:22 PM
I guess ima have to ride no ebrake for a while because all i have is the CRX Si ebrake cables and my hatch cables.
Old 04-01-2003, 02:18 PM
tehferret tehferret is offline
Send a message via AIM to tehferret
hey does the 90-91 civic hb si have rear disk breaks?? sorry but this one slipped my mind when i was reading up on air voulume vs. air mass. Thx Late
1991 Honda Civic Lx Sedan
Looking for a 90-91 Civic HB SI for complete SiR conversion!
Old 04-01-2003, 02:20 PM
GTA's Avatar
GTA GTA is offline
Whee..
nope only the crx si.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 04-01-2003, 02:23 PM
ehh ooh well thx. just wondering cuz i am in a debate right now either to go wiht a hb si or dx. just makeing pros and cons. Thx
CRX DX Rear Bushing replacement rusted '88 - '91 Civic | CRX | Wagon | Shuttlee 10 08-19-2009 11:08 PM
crx rear disc brakes on a 89 civic hatch 89civichatch89 '88 - '91 Civic | CRX | Wagon | Shuttlee 10 01-04-2006 05:47 AM
Rear disc brakes on 87 CRX Si Miguel Gonzales '71-'87 Civic | CRX 0 05-31-2003 06:49 PM
rear disc on CX hatch? 94tegRS Tires and Wheels 2 05-15-2003 02:50 AM
Rear disc conversion on a 96 hatch whttrshpunk Tires and Wheels 3 10-14-2002 01:42 PM
