Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 05-20-2009, 04:57 PM
eddie8 eddie8 is offline
help
Changed shift solenoids and iss on '96 concours, still no shift. Thanks.
Old 05-20-2009, 06:44 PM
maxwedge maxwedge is offline
A990 racer
Re: help
Wow not much info, no 1-2 upshift? Do you have a vacuum modulator on this trans, if so check for vacuum to it for starters, if not I would suggest a full scan with a trans function scanner. Any CEL?
Old 05-21-2009, 07:43 AM
Re: help
No up shift, has no modulator, no codes. Thanks.
Old 05-21-2009, 07:58 AM
A990 racer
Re: help
Ok, then the full scan is next as I said, also it may be starting in 2cnd which is a fail safe in some cases, make sure the main plug on the trans is seated firmly and no corrosion.
Old 05-21-2009, 09:10 AM
Re: help
Thanks. Will do a scan and check wiring.
Old 05-21-2009, 01:14 PM
Re: help
Scan showed no codes
Old 05-21-2009, 03:18 PM
A990 racer
Re: help
Maybe we are on different planets here, a full scan with a special scanner for transmission functions will allow for commanding the solenoids on and off as the pcm would do, a regular scanner will not do this.
Old 05-22-2009, 05:52 AM
Re: help
Thanks Maxwedge. I am going to get a trans shop to do a full scan like you said. My snap-on scanner shows a 1-2 shift but nothing else.
Old 05-22-2009, 06:30 PM
Re: help
Got it going. Used heater controls to erase history codes. Now car runs great.
