Old 05-20-2009, 03:59 PM
cobraprince cobraprince is offline
It just got worse...
you guys have all been super helpful, especially since I'm so new at this who car thing. But I have another dilemma i need help with.
My 94 stealth is turning over but not actually starting. And I have no idea where to start the troubleshooting. Can someone give me an idea please?
Old 05-20-2009, 04:06 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: It just got worse...
You have to find out why its not starting.
You need to see if you have spark, fuel, etc then go from there.
Old 05-20-2009, 04:30 PM
quackmandude quackmandude is offline
common things.
do u have gas???
spark,
f its turning u should have power.
not so common things
compression? bent valves etc.
sensors?? crank angle sensor will cause it to turn but not start. cam angle will to. make sure they r connected on the crank and cam as well asthe wiring harness.
um um um ignition module or coils (module is underneath coil packs.
if u cant do it urself get a mechanic u trust to check it out
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6)
Old 05-20-2009, 04:57 PM
It was kind of taking a few seconds longer to start than I think it should starting a couple of weeks ago. I just thought I could use a tune up... could a fried fuse be the problem? I pulled the engine fuse out and it was burned on one side.
Old 05-20-2009, 06:32 PM
o it could be that ur starters getting old, try replacing that
Old 05-21-2009, 04:09 PM
Alright, thanks for everyone's help. But it just turned out that my engine fuse was all burned up... I don't know how that happened. But when I changed it my car started right up.
Old 05-21-2009, 04:46 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Which fuse was it? I would say possibly a bad ecu that but not really that common on 2nd gens (94+). Take off the "w" connector on the right side where your fuel rails connect to eachother and have someone try and start the car to see if gas comes shooting through the front fuel rail. I would highly reccomend having a rag to catch some of the gas that will potentially shoot out.
Old 05-21-2009, 09:53 PM
I guess I could try that. But why would I check the ECU? And I checking it to see what caused the fuse to burn? I mean, my car starts fine now. It was the blown engine fuse. It's a blue 15amp, in the middle on the top.
Old 05-21-2009, 10:02 PM
VR43000GT's Avatar
Sometimes the caps can leak in the ECU on to the board causing it to malfunction and come up with problems like yours. It is much more common in 1st gens though.
Old 05-21-2009, 10:52 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
It's real easy to spot once you get the ECU open as well.
Old 05-25-2009, 09:23 PM
Once I get the ECU open I just look for fluid then?
Old 05-25-2009, 09:36 PM
VR43000GT's Avatar
You'll look for that goo crap that leaks out of the caps to be on the green electric board (for lack of a better word ).
