Old 05-20-2009, 09:16 AM
darrellf40026's Avatar
darrellf40026 darrellf40026 is offline
99 Voyager won't run
I really hope someone here can help me out here. I have a 99 Voyager that just refuses to run. It will start as long as you have your foot on the gas(and you barely have to have it pushed down to a particular sweet spot),but it won't idle.When you put it in gear it dies every time, no matter if you're giving it gas or not.It is getting fire to all 4 cylinders and there is no codes showing up either.
Any help would be greatly appreciated.
Old 05-20-2009, 12:34 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 99 Voyager won't run
Could be several things. First I would check fuel pressure with a pressure gauge. Pressure could be low and when you put the added demand of trying to get the van to move, it can't handle it. Weak ignition coil output could do the same. Other things that pup up are a throttle position sensor or idle air control valve
Did this come on all of a sudden or was it progressive? Any maintenance done just prior to this starting?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 05-20-2009, 01:55 PM
Honestly I'm not sure because they bought it real cheap in this condition. They put a fuel pump/fuel filter in it and a TPS. it does seem like its a fuel issue to me.
Old 05-20-2009, 11:14 PM
tempfixit tempfixit is offline
CHeck fuel pressure regulator
