Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 05-19-2009, 05:46 PM
wickedlowss wickedlowss is offline
Burning oil help 22re
My truck has about 20,000 miles on a 95 22re rebuild when i bought it, it burns oil on start up and when u accelerate, there is oil on the threads of the spark plugs and fouls them out, im not sure if it is the valve seals or rings, is there any way to tell with the head off, the cylinders look really good nice cross hatch pattern. thanks
Old 05-20-2009, 10:14 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Burning oil help 22re
A compression test can help find out where the leak is...disconnect the coil wire, pull the plugs, install the compression test gauge and crank it. Read the gauge then squirt about 1 tbsp of oil into the piston and retest. If compression improves, then it is the rings...otherwise, it's the stem seals.
If you're seeing rough idle and smoky exhaust mostly from cold startup, my guess would be valve stem seals. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 05-20-2009, 06:23 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Sit the head on some newspaper and pour some motor oil around the valve stems (just like it would pool around them when you shut off the engine).
Then wait and see if it leaks thru, just like it would on the engine.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 05-21-2009, 03:48 PM
I pulled a couple of the valve and the valve guides were broke off... guess that could be a problem.....
Old 05-21-2009, 08:35 PM
fourwd1's Avatar
AF -Advisor
Yeah
89 4Runner - stock
